lavron
pmuller9":1m4boqan said:Larger cams with increased valve overlap require more initial timing.
You may find that the engine wants more than 12 degrees initial.
I ended up somewhere above the top mark on the pointer, going to guess 14 to 16, and got it to idle descent at 750 RPM, after adjusting the valves twice I finally decided the ticking at the front of the motor is the PVC valve.
Also if I plug the PVC line the engine appears to run worse than when it is hooked up to the valve, is the carb designed to operate properly with what is, in essence, a giant vacuum leak you think? That may not even be the proper place for the PVC valve to hook up, I thought I checked that and it was however.
As soon as my slow internet finishes uploading the video I will link to it and you guys can hear it idling and see if you think it is ok.
See Ya,
Mike
Comgrats Mike great job getting the rocker arm lash set, that's really a good smooth idle now plus it's sure hitting on all six cylinders and It's so much quieter too! Little by little it's coming right along, yes I can hear now how the exhaust is rubbing
and one of the next things to fix. Once that's taken care of it's going to be hard to tell its even running at idle RPM's.
