Richard,
I don't want to rain on your parade, and I certainly don't want to discourage you away from programmable EFI, but, if I'm interpreting your posts correctly I get the feeling that you would like a "bolt it on, does everything for you" system. That's a tall order and I'm not sure that there is a solution for it. The latest version of "Tuner Studio" for Megasquirt is very good, but it's not a "silver bullet".
Programmable EFI can be very rewarding, but it is not for the feint of heart. You really should have a very good idea of what you are doing before you start, because you definitely will have enough rope to hang yourself.
I equate it to having a carburated engine, with conventional ignition, that you have never run before. You are given a very good quality carb, completely disassembled, with every possible combination of venturis, jets, air bleeds, metering rods, etc, etc, etc. You are also given a very good distributor, also completely disassembled, with every possible combination of fly weights, springs and vacuum advance assemblies.
Now, you are expected to put it all together and tune the engine as good or better than the factory did and not blow it up in the process.
I'd suggest that you do a bit of soul searching and ask yourself if you are up to that, and if you are, welcome to the loony bin. It can be lots of fun.
