I always liked that meter. It worked great for my 83 CJ7 until I changed to a new fuel injected engine. I'm not writing it off yet.B RON CO":3db47oc0 said:Hi, the Heathkit meters are very good. Verify it on another car if you can.
The lowest plug in the picture can be rich or probably oil fouled.
Good luck
edited
bubba22349":1x6hv4u6 said:X2 those Heathkit's where a very good quality in their day, I wonder if it might have a battery inside. Do you happen to have the instruction Manual for the meter? Unless you were using a tach / dewell meter as in a professional setting (full time mechanic or tune up shop) it's unlikely it could ever go bad, other then dropping it or other destructive forces. In any case checking it against another meter will tell the tale. Good luck![]()
edited
bubba22349":uycunl97 said:Thegrayghost, that is excellent news 680 RPM is at least close to the ball park and you can work from there. Still work at doing the first steps of plug gap, the correct dwell, and base timing before working on the carb settings. Good luck![]()
thegreyghost":3ougve9v said:bubba22349":3ougve9v said:Thegrayghost, that is excellent news 680 RPM is at least close to the ball park and you can work from there. Still work at doing the first steps of plug gap, the correct dwell, and base timing before working on the carb settings. Good luck![]()
These were taken a couple days ago before I realized the carb linkage was hanging up. Probably more like 1000 rpm.
https://drive.google.com/file/d/1hx9uMHOw_rZOxy1RgXxSBBfYlcmWnuOS/view?usp=sharing
https://drive.google.com/file/d/1iCUtnjzOgkvAkf5eLI5n5yzXULIDEUOU/view?usp=sharing
Hopefully these links work.
sounds great and is quite smooth! X2 now if you can get it idling down smooth at 600 RPM.
Econoline":58qa8gk0 said:thegreyghost":58qa8gk0 said:bubba22349":58qa8gk0 said:Thegrayghost, that is excellent news 680 RPM is at least close to the ball park and you can work from there. Still work at doing the first steps of plug gap, the correct dwell, and base timing before working on the carb settings. Good luck![]()
The links are working. Yeah it sounds like 1000+ to me. It sounds pretty smooth, sounds like the ignition system is working pretty well, no big misses. Not a horrible place to start. I'd like to see a video of it idling around 650, or as low as it idles nice, and you putting it into gear w/ your foot on the brake and holding it still. After you get the timing and the dwell set.
If you have the throttle plates all the way closed on the outer carbs at idle, w/their mixture screws turned all the way in and with a smooth idle, can you then kill the engine by turning the mixture screw in on the center carb? Doing that's making sure there aren't any vacuum leaks and the idle circuit is working right on that carb. If you can pass that you should be able to tune it up real nice.
thegreyghost":162tv416 said:Econoline":162tv416 said:thegreyghost":162tv416 said:These were taken a couple days ago before I realized the carb linkage was hanging up. Probably more like 1000 rpm.
Had a little time to play around today.
Got a video of it showing the tach at 600 and the dwell setting - about 27.
Got another video of it at 800 and then the dwell - about 34.
Not sure why there's that big of a difference, but I haven't measure the points yet.
I have both outer carbs disconnected and confirmed that I can get it to stall by turning the mixture screws in. Right now all three are 1.5 turns out.
Took if for a short drive - surges with the throttle. Doesn't have much get up and go yet.
videos are rpm first, followed by dwell.
https://drive.google.com/file/d/1eQ9IA1y6WARP9kZXpNcSU4E6TbnaUZLX/view?usp=sharing
https://drive.google.com/file/d/1JKrDGdhWNs6dETBhHzThKOu9d1iKNKoX/view?usp=sharing
Gene 64 2dr":1apqlt2n said:When you say you have disconnected the outer carbs, do you mean you just disconnected the fuel lines or did you block them off? To run on just the center you need to put a plate between the carb and the adapter. This will isolate them.
