That's a very good looking Grabber
Ha ha ha...so at least my car runs 14's somewhere on the planet!! :rolflmao:WerbyFord":1mp6l6cj said:Can't do much about your altitude though, but your et does correct to 14s as-is right now!![]()
Gene Fiore":1ucvdu65 said:Ha ha ha...so at least my car runs 14's somewhere on the planet!! :rolflmao:WerbyFord":1ucvdu65 said:Can't do much about your altitude though, but your et does correct to 14s as-is right now!![]()
No and yes!! LOLtri-power 250":1mad4m02 said:Did you put the battery in the trunk?
Don't you live in Arizona? Everyone knows Arizona never get's cold! :rolflmao:
Take care,
Ken
Yeah, I was thinking that I need to check with Rich. Might have to get some tin to seal that area off.Crosley":2bamjrn8 said:Gene, if you take the back seat out. That area still has to sealed off as I recall. I;d talk to Rich about that situation on what is needed by the rules
Right...I believe the rule of thumb is for every 100 lbs you take out you can pick up .10 second in et. I know the back seat doesn't weigh near that but, hey, when you are scratching for hundredths of a second it all counts!First Fox":3w2t7m6b said:Keep in mind if you are going for weight loss alone to lose the last 10th, it will have to be somewhere in the neighborhood of 100 pounds to hit 14's. Last time I removed a back seat it was from my Fairlane and it seems like the whole thing went less than 25 lbs. It was surprisingly light. If you are going to nickle and dime the last hundred pound make sure the tank is near empty. 8) 10 gallons of fuel = 60 pounds.
Soldmy66":2wktpslr said:This may sound abusurd, but it is worth a try - in terms of reducing your car's Cd.
Try running a grill block; something (even cardboard or coroplast) to block your grill (or a portion thereof) so as to cause the air to flow around your car - rather than allowing your grill opening to act as a big air brake.
If it was something temporary (cardboard or water pipe split tube foam insulation) , it could be removed to do A-B-A-B testing.
With some temp data, you could determine the minimum grill opening required to keep your car cool enough, yet minimize Cd.
Back on the street, the grill block could be removed.
