LMAO.... :rolflmao:First Fox":3ljc2suk said:Good job Gene!
Interestingly enough the phonetic sound "Good job", in Mandarin Chinese roughly translates to English as: "I respect you work in acquiring 14 second time of elapse in drag race, however with turbocharger car make elapse 12 seconds drag racing."
Cheers to you!![]()
Here were all the runs in the order they occurred....I wasn't hooking up very good on the first two passes but then the track came around.82F100":2690igbg said:Gene,
Congrats on hittin the 14'sany other passes in the 14's?
That will be the challenge...to get it to the point where it will still run 14's when it is 80 to 90 degrees out.xctasy":3jwsf1a8 said:Now lets see it continue to drop as things get hotter.
Gene Fiore":35jkukcq said:That will be the challenge...to get it to the point where it will still run 14's when it is 80 to 90 degrees out.
That's for sure...another forum I'm on is encouraging racers to write to governer Brewer to plead our case to keep Speedworld open. It will be a sad day if all the tracks in this area are closed.Crosley":lw6hx8aw said:Gene Fiore":lw6hx8aw said:That will be the challenge...to get it to the point where it will still run 14's when it is 80 to 90 degrees out.
It will be a challenge if SpeedWorld closes up.
I don't currently have a way to take a pic of the slip, but I can provide them for you. Here are the numbers from the time slip:FalconSedanDelivery":2fqxskby said:Do you have a pic of the time slip , Id like to see the increments 60fts etc , and how much does your car weigh with you in it , and congrats on hitting the 14's
Hmmm...all of my runs were shifting at 4800 rpm. The last pass I made I shifted at 5000rpm and the car slowed slightly, but maybe it was related to something else.WerbyFord":1hs952zx said:Strange though, the Gonkulator model of your car likes higher shift points, gains about .08sec and 0.4mph. Where were you throwing&completing the shifts again?
It was an aftermarket one from Summit Racing...here is the link:Mustang_Geezer":1sm8ywbr said:Gene,
Your 5" pulley for your alternator. Was it a power steering pump pulley or a aftermarket one like a Mr Gasket or Moroso. If it was a stock pulley what was the application?
Thanks!
Again, congrats on entering the 14's!!![]()
