Double check all your wiring.  I know you said you had the problem before and after your pertronix install, but check to make sure you have solid connections everywhere, especially with those spade connections.  I had my car randomly die on me because of a loose connection.
LIke CZLN said, it's the on again off again nature that is perplexing. Usually that indicates an electrical problem of some sort. Out of curiosity, how old is the coil? Check all your connections to it. Next time you get the pinging, pull over (at a safe spot) and keep the car running. Try pulling the plug wires off one at a time and checking the spark. Should be strong and should be able to arc across 1/4" at least to the plug. Strong and blue.
It's just the off and on nature that makes me think it's an electrical problem. Fuel pumps generally work or don't work. Carbs generally work or don't. Air is always there.
These engines are easy, but your problem is truly odd.
Also, next time it pings, try getting some pictures of the spark plugs as soon as you can. Those may give us more clues.
