Dose'nt sound like pingging to me more of exhaust tone with a missfire
			bubba22349":hbd73wyb said:A stock fuel pump with it's filter is good system, with all the filters sounds to me like tank must have a bunch of dirt and or rust. With a lot of trash in there it will plug filter than when it sits it will open up again. I would pull tank you can replace it or take to be cleaned at chemstrip or a good radiator shop after cleaning I use the aircraft slushing comp. to seal it.
bubba22349":3c6rid01 said:with all the filters sounds to me like tank must have a bunch of dirt and or rust
redxm":3rqmntfx said:I had a car once that had a horrible rattle at various times that sounded a lot like pinging. It turned out to be loose convertor bolts. May be worth popping the cover off and checking.
69.5Mav":2v2h2tdq said:I would check the flex plate for cracks and weather the torque converter is bolted up to the flex plate correctly
redxm":2v2h2tdq said:I had a car once that had a horrible rattle at various times that sounded a lot like pinging. It turned out to be loose convertor bolts. May be worth popping the cover off and checking.
Frankenstang":2v2h2tdq said:That's a very good idea...torque 'converter' bolts...you can check for loose/broken ones by pulling the inspection cover as redxm suggests
JackFish":2v2h2tdq said:Finally used a mechanics stethoscope to pinpoint where it was coming from.
thesameguy":jqmj2lk1 said:I don't think it could be a u-joint
thesameguy":3gk7oa4f said:It'd be kinda hard to have my head under the hood while going down the road.
69.5Mav":2dyvgm81 said:thesameguy":2dyvgm81 said:It'd be kinda hard to have my head under the hood while going down the road.
I had a thought on how you might be able to do that.
If you can find a smoke check station that will let you put your car on their load rollers.
Or if you can find a Dyno shop and instead of a HP pull ad get the car under load and search for the noise.
chad":2r3j293z said:Break area?
It would help to locate the "region" of the thing...
Under hood, near pass. floor boards, etc...
