That didn't sound right to me, cause every 1946 I've seen has a hex head screw with a slot for a screwdriver.sargentrs":36ica8yv said:So I'm turning the wrong screw. My TSP is removed and the screw I should be turning is the one on the passenger side, toward the rear of the carb. It's actually a 3/8 or 5/16 hex head bolt, no slots for a screwdriver.
So I took a picture and circled the curb idle screw:
The screw goes through a hole in the casting.
You may have been looking at the transmission kickdown adjustment screw.
You may have to loosen off the air cleaner to get to it.
