Yea, it's hard to look cool when your six sounds like the motor is falling apart!
After I used the A&B epoxy it shut up for a week or two but now it is back to rattling again. :x I just took the header loose and all the epoxy is gone. I may have not preped it good enough but it is hard to do to much with the head on the motor in the car. I don't want to weld it with it in the car with not much space from fear it could get screwed up. I figured in a few months the motor and head will be out of the car when I try out the turbo setup and then I can weld or epoxy it up RIGHT. So what I am getting at is do you guys see any bad effects from running nitrous and no port devider? Or will it be fine with maby a little power loss? I would think it would be okay but I though I would check with you guys to make sure.
Dan
Dan
