... following the wide variety 'bread-boarding' of this 200 vs 250 and Blow-thru vs Draw-Thru builds, pics' are worth .001's
Adapted to the inline six in the pics is late 70's to early 80's Buick/Olds/Pontiac V6/V8 draw-through carb'd setup . The specially ported for turbo Quadrajet is on the 79 Buick manifold to the Garrett TBO3 turbo. I adapted the some of the Buick V6's exhaust. If I swap in a small block 200 it is @1-3/4" shorter than the
stroked 250 height and may gain RPM/boost capabilities .
'Draw Thru - carb'd Turbo setup was the dominant variety until Fuel Injection made everything much simpler. Draw thru has a few
peculiarities from Blow-thru:
Draw thru always has fuel at atmosphere pressure so no carb boost-referencing or fuel return needed . Forced induction blow thru will probably require significantly
smaller carb spec than NA of same engine, Draw thru requires
ridiculous NA cruise to high boost CFM change. Specific OEM Quadrajet for small Buick V6 has external PV port and is spec'd at @850 CFM at high boost !. Draw-thru creates serious
venturi chilling at intake usually requiring intake
heating provision.
MacInnes makes no statement as to which method is best in "TURBOCHARGERS" . The problem with early draw -thru setups wasn't lack of performance as much as a warranty nightmare for the mfg. . With only enthusiast/light use of a homebrew draw-thru carbd' setup, there is not a real issue with MTBF for the setup.
.. started with getting engine running well NA, next added turbo and significant ignition timing mods. slowly increased boost and carb tuning for
safer AFR's until boosting
too optomistic at over 1 bar.. ... .
With a SCR of @ 9:1, the 'Effective Compression Ratio Chart" lists the effective CR at 20lbs boost at @ 21:1. Possible a mild built small block six can handle modest boost with a few simple mods , unless you really need to build for the most it can deliver ..
My Maverick now has a Blow-Thru Vortech SC setup and my BOP' Draw-Thru setup is moving to a (forged-piston) second attempt, just deciding on another 250 or the 200 , probably the 200 ? ...
