Just bought a 66 coupe with the 200. It runs, but not well. It will not start on it's own but if you pour some fuel down the carb it will start and then it will run on it's own. It runs rough but will rev up and idle. Under load it dies. So far all I've done is run a new fuel line from the tank to the pump. I plan on doing standard oil, filter, plugs, cap, rotor, wires and timing. Anything else to keep in mind? Also, where can I find a cap and rotor? Local Checkers doesn't even have a listing. I also have no experiance with points, where's a good place to learn? Thanks, Matt
