uhh...not so decent mileage
or I can call my front desk...it was delivered today!!!
ah...incompetant america......
...is the YF1 higher CFM than the YFA
Hmm...never seen a YF1. Try Mustang Geezers website. He lists quit a few carburetors and their respective CFM ratings. However, you might want to say away from the 240 & 300 carburetors. You may have hood clearance issues. I think they are RBS'
Or...you could go with a Holley/Weber 32/36 like I did just last week.
It was cheap! 65.00 for the carb. and 15.00 for the adapter. Kick in about 3 bucks worth of aluminum stock and .... BAM!
It flows about 280 CFM and because of small primary, the low torque is pretty cool at take off. :wink:
-Chris
chris you havent gotten a mpg yet have you....
I am sooo curiuos about that
No MPG yet. Hopefully next week I'll be driving the car to and from work. I should get a good estimate considering it's approx. 40 miles a day.
I'll keep you posted. :wink: :D
-Chris
-Chris
I certainly wont have hood clearance issues now...hehe...my custom hood allows for an extra 1.5"-2" of extra carb height if i need it. :D ....but 65.00 is really good...i think i'll see what they cost here...if its about the same, most likely a bit more $$ then i will definitely go that route...cant wait to see what kinda MPG u get.
well i loosened the accelerator pump screw one full turn and since i couldnt find any jets i took the jet and played the end with some pliers and managed to fairly neatly crimp the end so it was a fair bit smaller..still bigger than stock but i have no idea how much, i sorta bog a bit from 0-30 MPH but its not toooo bad, but after 30-35 MPH it starts to giver...fun to watch the acceleration needle go slower and then all of a sudden speed up...but all in all I managed to cut gas mileage approximately in half...I took a trip yesterday that normally would have taken almost 1/4 tank of gas and this time i only used not even an 1/8 of a tank...same driving pretty much...but its waaaaaay better...i think i will leave it like this for awhile...then check my plugs again and see if its any better...still smells a little bit rich, but at least u dont eat the fumes.
Dave, have you thought about plugging the jet with a two part adhesive and redrilling the jet?
I know here in the US you can get just about any two part adhesive you can think of. Try JB Weld, they say it's resistant to gasonline plus it's drillable - I know. :wink: http://www.jbweld.net/coldweld.html
-Chris
i actually have thought of that...just wasnt sure how good it would be incase it came loose and went into the engine...
Well, I think as long as the surfaces you are plugging are very clean, it should be alright. Besides, if it does come loose a piece of filler that tiny wouldn't hurt a thing.
-Chris
