66200i6
It took me awhile but I finally found the thumbnail page I have put together some time ago showing my DizzyII, 32/36 and header install. If you look through the thumbnails you will see the modified Throttle Rod and how the 32/36 DFV throttle is actually in the same location as the stock carb. All that is needed with the DFV carb is a change of throttle lever from Pierce Manifolds and an extended connecting rod.
I hope this helps some, Ric.
https://home.comcast.net/~tuckerjr3/headdurainstall/HeadDuraInstall.htm
