White Lithium Grease
Has anyone thought about using lithium grease to coat any interior moving parts when performing an engine rebuild?
I thought about applying some to the rockers and around the crank as well as around the bearings for my 351W project.
-Chris
Mixing greases can cause very bad things to happen.
Before you do this, check to make sure that the Lithium is compatible with oil.
I have used white grease on bearings with no ill effect. Still, I prefer to use the Moly assembly lube, esp for the cam and lifters.
Cool.
I thought I had read somewhere that using Lithium Grease on the cam and crankshaft was an acceptable alternative.
Thanks again!
-Chris
8) lithium grease is fine for the crank and cam bearings, but NOT the cam lobes. there you need a quality cam lube otherwise you risk wiping a cam lobe in short order. like jack i also prefer to use a good moly based lube.
