Autolite 1100 on 200 inline six
If you can find a radiator shop that is where I had one cleaned out before. Like in 1989 or something.
I cleaned out old metal tank-to-pump fuel lines by removing the line at the tank (was installing new tank anyway) and spraying brake cleaner spray into the line in the front, followed by compressed air. Continue process until it blows out clean at the rear. . Not as effective as replacing the line, but works well enough. On that vehicle I then used an inline filter before the pump. Normally the inline filter should be after the pump, as gas "boils" into vapor at a relatively low vacuum. Better for physics and the pump to have the filter on the pressure side of the system. After about one tank of gas consumed, any remaining light debris from the line is 95% cleared out. After a couple of tanks I replaced the inline filter, moving it to the carb side of the pump and no further issues.
Replace any rubber line too, if its old. Alcohol is hard on the system. (don't forget the short rubber piece at the tank). :)
Hello of of you that have supported my effort. I decided to play it safe and remove the fuel tank to ensure that is clean.. Reason is that after I tune the cat with the existing Autolite carb I will be installing a tri power Offenhauser so I want to make sure that the tree carbs will be free of debris from the tank. Easier said than done. Whoever installed the tank in 2020 the y used, I Think PVC cement and the tank is stuck and cemented in the frame of the car where the tank goes. I am using Isopropyl alcohol to see if I can soften the joints and pull the tank away. If this becomes a real issue then I am planning to replace the sender unit and in that hole see is if I can clean any garbage that was left behind after draining the tank.
Can any of you recommend anything with regard to the removal of the tank?
Appreciate your comments
