The Wife and I Just picked up the engine . Done Deal . Headed back home . Will post picks soon
chad":3jtmdezi said:may B ck the snout length on the W.pump? I gota GMB for my (non-Oz) 250 ina bronk and it looks shorter.
If U want give me the number, meanwhile I may B able to find mine (part #) altho it's beena yr...
Great job Falconcritter, its sure looks like a regular US 200 six block to me! Those GMB water pumps are excellent looks like with the gasket set all you need are the bolts to assemble it into the compleate long block.
bubba22349":34730211 said:So you might want to measure the top of piston to get the block deck height measurement, looks close to a zero deck height. The bore size think you said .040 ove so 3.720, next also CC the heads combustion chambers togeather with that info and head gasket thickness (looks like maybe has the Victor head gasket if so that's .044) now you can calculate the Static Compression ratio. Next you can check the cam timing events with a degree wheel and dial indicator and you can calculate the Dynamic CR. Good luck![]()
! That is a little too much for the street . And not looking to go that far into my car at this time . i will see what the cam says . ANYBODY WANT TOO BUY OR TRADE FOR A RACE CAM ?
