D Dustyford Well-known member Today at 10:12 AM #241 drag-200stang said: If you have not done so, while you have the head off, check that the damper timing mark is correct. Click to expand... Absolutely
drag-200stang 2K+ VIP Supporter 2020 Supporter 2021 Today at 10:18 AM #242 You are quicker that my edit, I added that the oil slinger will not work with the roller set and is not needed if you have one.
D Dustyford Well-known member Today at 10:26 AM #243 drag-200stang said: You are quicker that my edit, I added that the oil slinger will not work with the roller set and is not needed if you have one. Click to expand... Yes, I have read that
