mysavioreigns
Well I finally moved everything around and got the distributor (DSII) all set up, started it up and it ran like a champ. Plugs were around .035" - .040". It would run about 3-4 minutes or so, then get real slow, and die. (oh, this is all at idle in park)
So, I regapped the plugs (for the DSII specs) to about .045" - .050". The car was much harder to start, but finally did, and it ran for only about 10 seconds before getting slow and dying.
So, my guess is that the module/coil is not sending enough spark. Could this have anything to do with the ballast resistor I (think I) still have under the dash? This would cause a lower voltage, and could be the culprit. Only reason I didn't remove it is because it was dark
I'm running the DSII, 5200, and the GM HEI module. Also for the record, my plugs looked rich when pulled.
