Stevestang,
sorry for the late response, I get so easily distracted on this forum.
for my setup I did go a little bit on the expensive route, only because I wanted this to work very well, and not deal with it again. (I tried dual 9 inch fans offset with bad results with the AC on)
http://www.summitracing.com/parts/DER-16217/?rtype=10
here is the link to the fan I bought, although I'm glad i didn't pay the current price.
I went with this fan due to the fact that it sits 2 5/8 inches high (low profile) and it pulls a wooping 2400cfm, the other benefit is that it covers 77% of the radiator surface. I did have the plasitc ties on but I disliked them as they moved the fan and bent fins. So I built my own brakets for the fan, I'll take a pic and post it later tonight.
I have a 65 mustang, made in december of 64, so I assume my car is very simular in the engine-radiator room. I had to "persuade" with a 2.5 lbs hammer the radiator support to push the radiator forward, I gained about an inch, I know it's not pretty but you don't see it. the fan fits with enough room to fit a fan belt between pulley and fan so I can change it easily if I need to on the road.
I did have a fan controller to trigger the fan to turn on at X temp (170*???) but when it got too hot it burnt out, so currently I have a switch controlled by me, I find it conveinient and inconvienient at the same time.
I am very pleased with the performance of this fan, I would gladly recomend this fan to others. just stay away from cheap temp controllers as I havn't had any luck yet.
