I talked with the design engineer again today. It's finally done.
arty:
Now for the good stuff, or at least some of it.
We were shooting for 65% on the exhaust flow. He hit 73%.
arty:
The design will work extremmly well N/A or with boost, and is prefectly suited to a roots style blower. With the high velocity ports, fast burn chambers, 192/144cfm @500, excellent quench, 11.5 CR capability (n/a), and 100% fuel distribution, this thing is going to be Awesome.
We should be able to start the pattern work late next week and are shooting for an early to late spring release date. Once the first proto type is produced and we verify the flow numbers, I'll release more info on the exact numbers. All I can say, is if you install one of these, you'll need to invest in a set of street drag radials, not to mention an upgraded exhaust system (2.25" dual outs - mimimum, 2.5" is recomended). Bottom end torque will come on fast and strong and will keep on going thru mid range into the upper RPMs. He NAILED the design and exceeded our original specs. I couldn't be more please with the results. I can't wait to dyno the fisrt head, which will be videographed and put on a C/D.
With all the other parts we are working on here at SEMA, I think 400HP is very doable and 600+HP (with massive amounts of torque) may not be out of the question, with the right components.
We still need to get the 4V intake designed, but he is starting on it next week. But the intake is easy and fast to produce, in comparison.
