65 Mustang
Hey Guys. I noticed today that my cylinder compression varied significantly depending on how tight I made the rocker arm shaft assembly screws. When I torqued them to specs I got no compression in the first two cylinders and 150 psi in the rest. When I loosened the first two rocker arm shaft bolts the compression on those cylinders jumped up. Even got them to 160. I am not sure what the cause of this is. I would like to be able to torque them to specs and get high compression. I do not want the bolts too loose. Could it be that the valve springs need to be replaced? Could it be a worn or warped rocker are shaft causing it not to seat correctly? Has anyone experienced this? Any ideas would be appreciated. Thanks.
