Thanks for the reply. The car will idle fine. It only dies on deceleration at first and then starts to run real bad and barley makes it back. It dies, I start it and drive a bit then it dies again etc...
I do have an update though. I decided to go back to basics and have a closer look at the ignition system. I only have 5 volts at the + side of coil. I should be around 8 due to the resistor wire? Seems very low and could be the cause of appearing to run rich. I bumped the starter and could only get either 0 volts or 5.
I am going to hook a 12 volt wire from the battery and try to drive it a little like that.
I had to change the pink resistor wire a few months ago. It showed around 8 volts at coil and worked great after the change. If this is bad again I wonder why?
Any ideas...
