All Small Six Winter Project: Better breathing with a large log
I think the guy in the video said he used 50* a lot. But not on a sixđŸ€”
I think he was talking about his seat angle preference when he said 50°. I think ours will be 45° seat angle. He seems to work on really exotic high performance stuff.
  • Like
Reactions: DON
@Engine Fan : What tool did you for the backcut and the radius besides the drill press? File or stone?
Also here is an article from Joe Mondello who also talks about backcut and breaking the edge of the intake valves:
"Reface valves 45 Âș undercut 30 Âș the same width of your 45 Âș primary seat angle. On the upper edge of the 45 Âș next to the margin set your valve re-facer to 50 Âș and break the edge .005” to .007” wide."
File and emery cloth was used.
And yes break the edge of the margin next to the seat, but leave the combustion chamber side of the margin sharp
Thanks, good advice about leaving the chamber side edge sharp, I was wondering about that...
Also your valves look so precisely cut, I thought you machined it with a professional tool... really a job well done
Did mine for a 300 on the drill press. Lapped the seats after(gray line). Has always been part of a build for me.
No need to backcut the exhaust(one way flow)
Just radius the margin on the exhaust
Keep the intake margin sharp.
This is exactly what I was proposing to do with my drill press and a file. I figure I can build a jig at 30 degrees for the file so that I can get that back cut right and only back cut the intakes and only radius the front of the exhaust margins.
That info from the article @clochard68 posted fills in some knowledge gaps too.
I’ll see what the shop wants to charge for doing that. If it’s an unreasonable amount, I can still do it myself.
