Dustyford to do & check off list:
(tests and findings will be posted here for reference)
Engine Initial Timing 10-12 degrees ok
• Timing mark on flywheel damper: ok
• Engine Compression: ok
• Camshaft Degree: ok
• Fuel Pressure: 3 lbs. ok
• Distributor: run vacuum canister leak down test. ok
• Fuel: Using ethanol free. questionable
• Ignition Coil Test: ok
Do these tests in order:
1• Test Carburetor Idle Circuit: ok
2• Exhaust Restriction Test:
Remove Exhaust Down pipe from exhaust manifold outlet. No restriction ok
3• Check the vacuum at Wide Open Throttle under full load @ 3,000 rpm on the highway for 5 to 10 seconds.
To do the test:
Buy a cheap small roll of vacuum hose so you’re able to mount the vacuum gauge on the windshield with duct tape. Mount the gauge where you’re able to see it without obstructing your view.
Note:
The vacuum hose should be able to be ran between the fender and side of hood or between back of hood and near fire wall without pinching the hose totally shut.
To do the test:
Note:
