Pro charger mount
pmuller9
5K+
Supporter 2018
Supporter 2021
Do you have the Callies/Compstar rods and pistons yet?
Are you still using the 240 head?
What are you planning for a compression Ratio?
Pmelsness90
Ended up not using the callies rod I'll have to look back for the part number and application but i recall the rod being a 351 rod, still using the 240 head since its ready to be installed, the compression ratio will be 9:1
pmuller9
5K+
Supporter 2018
Supporter 2021
Ford small block V8 rods are only .825" wide at the big end while the 240/300 rods are .992"
What did you do to keep the rod centered on the crank journal?
