Jmustang_65
Update?
It's been a busy two years and I've had to put the car on the back burner. I couldn't get the cam sync timed correctly and the computer would not read it so there was no spark.Update x2?
See post 59, 60 and 61Curious what type of cam sensor and trigger set-up are you using? At some point you had a modified 3.8 cam sync/oil pump drive.
Sounds good. Glad your still at it.Still using the same cam sensor. Here is a video of the engine with the new cam. It needs to be tuned - it's running rich. When I moved, I lost the tuner who helped with the original tune . I'm working on a lead for a local Holly expert. The new cooling system (electric water pump ) works really well - It cools the engine down from 200 to 180 in a couple of seconds. And, I am aware the brake light is out - The problem is in the steering column.
That is some sloooooow melting snow...Not yet. When the snow melts I'll post one.
Should of reminded him a few months ago, I think that it is snow time againThat is some sloooooow melting snow...![]()
My money is on the turn signal switchStill using the same cam sensor. Here is a video of the engine with the new cam. It needs to be tuned - it's running rich. When I moved, I lost the tuner who helped with the original tune . I'm working on a lead for a local Holly expert. The new cooling system (electric water pump ) works really well - It cools the engine down from 200 to 180 in a couple of seconds. And, I am aware the brake light is out - The problem is in the steering column.
Very good point. But I live in the deep south so we usually don't get snow at all and that always throws me off.Should of reminded him a few months ago, I think that it is snow time again.
