All Small Six Back in the Saddle
You have found out why the Argentines use a pinned type of cam-follower. Even if you can get the tie bar type to work, what about the camshaft? It needs to be hardened steel, complete with the oil pump drive gear. Good luck.
Being that the casting is between the lifter pairs, does it interfere with the lifters?
Not sure until I play some more. TBH, I'm leaning towards just grinding the whole thing out and plugging the hole. I do believe that's the mounting point for the coil and I don't plan to mount there anyway.
Those guys are not fooling around. I think that they do the pin is because it kills two birds, a lot less weight and two, easier assembly. It may be that the link will not work on a 200 South American block and may not work on a 200 U.S. block ,I know that there is a lot less room on a 200 US block compared to the US 250, time will tell.
I've seen that the bushings are $35-50 each before you even buy the lifters. I wasn't on getting crazy with the grinder. Just enough to pass. It isn't going to take much. Good point on the button. I can take a little from each and reduce my risk that way.
They have a 188/221 block, much like we did, its a higher deck than the 200 to accommodate the longer stroke, 188 is 2.94 and 221 is 3.46, you guys never had these.
