All Small Six Back in the Saddle
They do appear to be ever so slightly biased. I also took pics of how I have the cam installed. I centered it on the bearings because I don't have it torqued into place.
On a 300 six the front of the camshaft's front bearing journal is even with the front of the block.
Since your engine uses a thrust plate the front of the camshaft should also be flush with the front of the block
Please measure the first two lifter bore locations.
Install a stock lifter in the first lifter bore and measure from the side of the lifter to the front of the block.
What is that measurement?
Next install the stock lifter in the second lifter bore and measure from the side of the lifter to the front of the engine block.
Add 1/2 the lifter diameter to those two measurements to get the lifter bore center locations from the front of the block.
Next measure the first cam lobe location from the back side of the cam lobe to the front of the cam journal.
Then subtract 1/2 the width of the cam lobe to get the lobe center location from the front of the cam.
Then measure the second cam lobe location from the back side of the second cam lobe to the front of the cam journal.
Then subtract 1/2 the width of that cam lobe to get the lobe center location from the front of the cam.
What measurements did you get?
The difference between lifter bore centers and the cam lobe centers from the front of the block will be the roller cam lobe offset needed to make roller cams.
The roller cam lobes for the 240/300 roller cams had to be repositioned .095" back from the flat tappet cam lobe locations.
I'll take a look this week. Was at a Cub Scout campout this past weekend.
No pressure on this but, any more head way?
Not yet. Monday I had to drive my kid to soccer practice 1.5 hr away and last night we had Cub Scout meetings. Kids and their schedules have been a major damper on my progress. I was able to get a bunch done the previous weeks because I had to work from home a number of days. I'm hoping to get out there tonight while my daughter is at dance. Fingers crossed.....
Your children are an investment of infinite value. Relatively- "stuff", including classic cars/engines, is nothing. (When old enough, they can be incorporated into assisting with the mechanic work. Accomplishes quality time, and they learn a valuable skill while you get your projects done. Win-win. :) )
