There's a leak on spark plug no. 4. I've checked the nuts and it's tight enough. I pulled the plug and the engine didn't stutter, which means I got a non-working cylinder perhaps? I haven't opened the head. Maybe this weekend when I have the time. What could be the cause?
Here's another problem. After an hour of driving, the car's engine died. I checked everything: fresh battery, connections are not corroded, oil filter is ok, fuel is 3/4 filled, air filter isn't clogged. It starts hard only after a couple or more. It will hesitates while driving. I pulled over and saw this tube (for engine oil) is smoking like hell. I removed the cap took a picture but wasn't able to capture the smokes. Engine oil level is ok. What's happening?
Please help me on this one, Thanks a lot!
For pictures please check out this link:
http://www.cardomain.com/memberpage/542464/2
