That above post is referring to the 1969 & 1970 Mustang 250 Six Mounts that CoupeBoy was making they would probably also work for a 1967 & 68 Mustang. The 1964 1/2 to 1966 Mustangs though have a narrower chassis than the later cars so they maynot work.  200 to 250 swap notes in the old Tech section here. https://fordsix.com/ci/250Swap.html
In these posts is the info for the 1964 1/2 to 1966 Mustang 250 Six swap mounts that CoupeBoy was also making might have some other info you can use.
					fordsix.com
One other 250 Six Swap in an early Mustang with more good info. Best of luck!
					fordsix.com
Installing 250 in a 65 coupe question.
For anybody that has done this before. I know the 250 is about 2" taller then the 200. I have the Maverick motor mounts for it. I know they will help lower a little but not sure how much. So how much will that help lower the engine? just trying to know out how much hood clearence I will need. Thanks
200-250 motor mount locations
Hey all,  I've been planning a 250 swap into my 1966 Mustang for a while now. I know pretty much everything that needs to be changed or modified. To fit the 250 under the hood without making a scoop, 250 engine mounts are needed. I'm curious where the holes for them have to be drilled in...
